top of page
A multi-axis robot perfectly balances power and size
Ideal for:
○ Machine Tending
○  Bin Picking
○  Mobile platform
○  Lab Automation
○ Robotic Research
​Performance
BRIEF INTRODUCTION
Durable Collaborative
robots for your automation
Industrial-grade harmonic drive and servomotors guarantee 24/7 working without stop.
Crafted from Carbon fiber, 15kg weight makes it possible for easier deployment.
robot automation
Flexible deployment with safe feature
Hand teaching, lightweight, space-saving and easy to re-deploy to multiple applications without changing your production layout.Perfectly for recurrent tasks.
Collision detection is available for all of our cobots. Your safety is always the top priority.
desktop robotic arm
Compatible with various of operating systems, including macOS and Windows.
Web-based technology compatible with all major browsers.
Drag and drop to create your code in minutes.
desktop robotic arm for sale
Fully functional open-source Python/C++ SDK provides more flexible programming.
ROS/ROS2 packages are ready-to-go.
Example codes help you to deploy the robotic arm smoothly.
Powerful and open source SDK at your fingertips
buy desktop robotic arm
desktop robotic arm accessories
Seamless integration with official accessories
Our robot arm can equip with a range of accessories to easily achieve the application you need.
Gripper
BIO Gripper
6 Axis Force Torque Sensor
Linear motor
Beginner-friendly
Working range
SPECS
Working Range
Working space of xArm series (unit: mm)
Note: The following working range diagrams are only for safety assessment.
desktop robotic arm online
Dimension
Dimension
Robot tool head
desktop robotic arm price
Robot base mounting (mm)
Comparison
Hardware
Hardware
Robot Specs
The control box is included in default.
Compatibility
Compatibility
Interface
Windows 10, macOS 10.10 or later, Ubuntu 12.04 or later.
API Compatibility
Interfaces with any product that has an API
Our robot API is open-source and users can make adjustments to the software as needed to interface with other products. While all integrations are possible, they all require custom code work i.e. most customers will need to write custom libraries and install software packages that are not shipped with the robot.
Open-source APIs GitHub.
Learn more
Hardware Compatibility
12~24V general purpose inputs/outputs
ModBus RTU (RS485)
Software
Service & Support
Software
UFACTORY Studio is a web-based software running inside the control box, which means no additional installation needed before running the robot. Any computer with a browser has the access after 1 minute hardware connection.
multi-axis robot
Service & Support
Warranty
1-year warranty against manufacturer defects
Stress tested to last a minimum of 3 years of full-time use
Certificates
Certifications complete (CE)
Demo video
Demo videos
From $5,799
bottom of page
